I don't see any error reports. What would it mean when the water fill is not in the pipe? This is an existing pipe network - I know it looks silly.
Joe Bouza
Hello Joseph,
Can you please let me know the steps so that I can reproduce this at my end. I think software is doing something wrong here.
Amit Garg
I would have pssed it up either
Joe Bouza
I agree - It looks way wrong. And when I first became an engineer I worked for this older fellow that liked to say "if it looks right it's probably right...If it looks wrong its probably wrong.... he was pretty smart.
This may get complicatd to wright, but I'll try.
1. exported civil3d parcels for my sub-basins
2.hear is where it got tricky ( maybe too tricky) I created a Map3d. shp file of the parcels and an excel spread sheet with %impervious, eqiv width,.. off hand cant recall but ther wer other inputs for the subbasins. Then using map I joined the input parameter to the parcel.shp file.
3. In SSA I used the GIS import to add the input parameter to each sub-basin
4. then I added the pipe network fro civil3d
5. tied the appropriate subbasin to inlets
6. run analysis : Modified Rational, user defined Tc, Hydrodynamic (thank you) routing
I thin my little input file trick may have messed thing up.., Ican post my spf file tomorrow in the afternoon. Thanks
Joe Bouza
I cant attach an spf file ?
Joe Bouza
Zip the file and attach.
Thanks. Can't see the forest through the weeds I not sure how to interpret the results, it tells me I have flow but the HGL and Max HGL lines make no sense, particularly since it does not display water. I've been mucking around with the storm duration but nothing seems to change. I appreciate you taking a look if you can.
I modified my sub-basins since the plot show(I'm sure they were hosed up from me trying to get cute with GIS)
Joe Bouza
Ok -
Not sure why the water "drops" as you show in the OP.
@Matt.Anderson wrote:Ok -
- Modified Rational duration of 1440 minutes - yet your rainfall amount stops at 60 minutes. Add additional durations to complete the IDF curve so that the duration of the storm matches the appropriate rainfall.
- Plain Rational method will select the PEAK runoff from each basin.
- Modified Rational looks at Volume of overall runoff - if you had a pond - this would be important.
- Watch the Node Starting WSEL for you catchbasins - they are "extracting" flow from the system and holding it.
Thanks for taking the time so late on a friday.
I had the duration initially set for 60 minute, I cranked to see if that was the prob.
I am looking for the volume runoff for a pond. where does Mod Ration tell me this?
what should the WSEL be? Those are default from importing from civil3d
Have a great weekend
Joe Bouza
