Civil 3D Forum
Surcharge Junctions
4 REPLIES 4
Cartexeng
364 Views, 4 Replies
Surcharge Junctions
This has to be a really simple solution, but I just cant see it.  On the attached model, I have a Jun-B2 and a 12" SD to a rain garden.  Jun-B2 is surcharged no matter what I change.  Pipe size doesnt matter; Surcharge elev can be 20-ft above invert and it still surcharges.
Same thing is happening with Jun-A2.
File extention should be SPF, but would not let me attach so changed extention to ".bmp".  Sorry for the inconvenience, but only way I know to get it posted.
Thanks in advance.
4 REPLIES 4
annw2
in reply to: Cartexeng
I don't know spf.  I tried double clicking the file and it won't open.  It says it is corrupted.
Have you checked your initial tail water condition?  At least on older versions, if you renumbered, it would set the tailwater to odd values or not update the tailwater values.  I always manually set every time I run.
Ann Wingert, P.E.
Cartexeng
in reply to: annw2
I figured it out.  Effectively, tailwater was the problem.  I raised the invert elevations of the pipes flowing into the detention pond and the surcharge went away.  I ran the model using Kinematic link routing instead of hydrodynamic which accounts for backwater and everything worked.  So I knew the problem had to be HGL from the pond running up the pipe.
Thanks for your response.  I appreciate the dialogue.  SPF is a file extension for Storm and Sanitary Sewer.
wfberry
Just a reminder. The next time you may want to send in an .spf file, change the suffix to .txt. This works easier since when selecting a .bmp most computers will try to load a picture file.
Bill
Cartexeng
in reply to: wfberry
Good idea - will do.  Thanks for the reply.
Rail Community
