Because of the limitations of the pipe or structure tables, for the last few years we were creating static Excel spreadsheets for Structure Data Tables. Wanting to take advantage of C3D dynamic tables, I was able to create one structure/pipe data table, but the pipe information is not linear on the table. This current table is confusing to Engineers and Contractors. Just want to know if I just need to use separate Structure Data Table and Pipe Data Table and stop fighting the program?
Jonathan Kipling, PE, CPESC, CPSWQ, GA Level 2 Certified
Civil 3D 2014
Solved by Hidden_Brain. Go to Solution.
I usually create a structure table with inflow/outflow pipes and a separate pipes table, example attached. So far I have been lucky and gotten away without anyone getting mad at me saying the tables are not easy to follow. just a thought.
