AutoCAD Civil 3D - Stormwater
*Expert Elite*
tcorey
Message 1 of 3 (139 Views)
Strange areas of subbasins
139 Views, 2 Replies
02-13-2013 01:29 PM
I am working with some new users and running them through some examples in SSA 2012.
One of the students can draw one subbasin and corrrectly gets .541 acres as an area. She creates another subbasin next to the first and the area comes up as sixteen acres. Looking on the screen, the two subbasins are similar size and when I digitize them on my 2013, both areas are correct, .541 and .488.
Any ideas?
TIA,
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Product Support
Matt_Haokip
Message 2 of 3 (132 Views)
Re: Strange areas of subbasins
02-14-2013 07:09 AM in reply to: tcorey
Hi Tim,
I can't replicate the problem you described. I could only think of that situation happening if the first subbasin was digitized based on a background drawing and the second one after removing the background.
Can the end user replicate the problem repeatedly?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
*Expert Elite*
tcorey
Message 3 of 3 (129 Views)
02-14-2013 07:58 AM in reply to: Matt_Haokip
Hi Matt,
Thanks for the response.
I can't replicate the problem either (I'm using 2013) but the user definitely can, using 2012.
The subbasins are being digitized over the top of a tif image. She did the first and second subbasins within a minute of each other. Looking on the screen, they are practically the same size, but looking at their properties, one is thirty times larger. Another user is getting the larger subbasin size on all of his subbasins, while yet another student is having no trouble. We are all using the same dataset.
For actual jobs I have recommended they work around this issue by creating parcels in Civil 3D and exporting to LandXML.That is giving them correct results.
Best regards,
Tim
Tim Corey, Owner
Redding, CA
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
