Civil 3D Forum
Storm struictures not correct in profile view.
1 REPLY 1
303 Views, 1 Reply
My storm structures and pipes come out great in the plan of all my drawings. But when I create them in a profile, some of my storm structures look incomplete. The storm manholes that have a invert elevation of more than 4 feet deep from the surface are fine. It's when I try to create a storm manhole with an invert elevation 3 feet from my surface, the structure has double lines on the side and no top or bootom to it. Has any else had the same problem?
1 REPLY 1
wfberry
Just a reminder, questions of this nature should be in this forum:
http://forums.autodesk.com/t5/autocad-civil-3d-general/bd-p/66
This stormwater forum is primarily for questions related to SSA (Storm and Sanitary Analysis) and the Hydraflow programs.
Now back to your question.  You need to look at the minimum vertical height of the structure you are using, perhaps use one that has no grate.  Try changing to a different structure to see if this works for you.  The structure you are trying to use probably cannot be made that short.
Bill
Rail Community
