I'm relatively new to SSA and want to use it as my primary hydrologic and hydraulic modeler. It only makes sense. Well, I got the program to work and had things linked in and was able to route a storm through the network. But when I routed the storms, I had to model double the storage that i expected.
So I went back to the program I'm familiar with - Pondpack by Benltey - and designed the same system I routed in SSA in that program - and got the storage volume that I would expect for a site of this size - about 2 acres.
Is there possibly a setting that I'm missing that makes my outlet structures route slower or less than they should? Or is there some other reason that a system would give this kind of inflated need for storage?
RVP-Rob42-
There are a couple of possible differences.
Can you attached a PDF of the PondPack? and a zip of the SSA?
Rob -
I dont see the PDF or the SSA files in your message.
I am having the same problem. The pond sizing in SSA are significantly larger than expected. This is causeing some permitting problems and we have abandoned the use of SSA for HydroCAD.
I would really like to continue with SSA, but cannot figure out where the problem is originating from.
tmurphy -
Feel free to reach out for assistance. Upload the model here as zip file.
One item to consider is reviewing the routing and reporting time steps.
Thank you for the response. I have attached the file as a zip.
What are you expecting for volumes that HydroCAD provides?
Your SSA modeling appears good, the pond fails for a minor amount of time and needs a bit of freeboard to avoid a flooding warning. (0.1 feet)
The Rim elevations for the manholes are much lower your initial model starting water surface elevations. The output contains a number of warning to that effect as well.
Are your subbasin areas overriden? They look like they were imported due to shapes, but the actual sizes do not match.
HydroCAD is telling us we need a pond that is 47,589 cuft. SSA is giving us a volume of 68,513 cuft.
Yes, my subasin areas are overwritten.
Thank you for the feedback.
Sounds a bit like apples and oranges might be going on.
Are the basin sizes / CNs the same?
Are Rainfall distributions the same?
Can you attach your HydroCAD output?
if you want, attach both your hydrocad and SSA models here, I have access to both softwares (HydroCAD 10 and SSA 2013), and would be more than happy to take a look.
I realized after my first reply that you had attached your SSA model previously.
i just set up a dummy HydroCAD model with your drainage area values for C1, C2, C3 and C5, ran it for Indy Huff 1Q 2-Yr (3 inches), and I get the peak flows and runoff volume results pretty comparable between HydroCAD and SSA (see attached image). I would imagine of the subbasin peak volumes are similar, the detention storage volume required should be comparable (i did not code in detention in HydroCAD).
Please check in HydroCAD>Calculation settings>Time span. I set it up to start at 0:00 and end at 24:00. i think HydroCAD 10 defaults this to stat at 5:00 and end at 20:00, which may be the source to your problem.
good luck!
