AutoCAD Civil 3D - Stormwater
*Pro
180 Kudos
Post 1 of 5
SSA - Inlet Rim Elevations and Weir Flow
619 Views, 4 Replies
12-08-2012 01:10 PM
This inlet scematic is tough for Inlet Rim Elevation.
Do I have all of the following Rim Elevation situations correct?
Also, does SSA include all four sides of a grate inlet that is not in a curb setting for its perimeter length in its weir flow calculation?
Fred
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
Employee
34 Kudos
Post 2 of 5
Re: SSA - Inlet Rim Elevations and Weir Flow
12-10-2012 05:45 AM in reply to: fcernst
Fred -
The Inlet Rim Elevation would the elevation at the gutter flow line.  The Combination Image shows a depression, so you've labeled the top of curb opening.
Matthew Anderson, PE
Product Manager
*Pro
180 Kudos
Post 3 of 5
12-10-2012 05:52 AM in reply to: Matt.Anderson
Thank you for the clarification. Makes more sense.
It just looked like in that schematic that it might have been pointing to that dashed hidden orthoraphic line that goes to the top of the opening.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
Active Contributor
1 Kudo
Post 4 of 5
12-18-2012 12:59 PM in reply to: fcernst
Fred
In response to your second question... I have asked this before.  Not much help, but you can look at the following thread for some more info:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Stormwater/SSA-Drop-Inlets/td-p/2754376
*Pro
180 Kudos
Post 5 of 5
12-18-2012 02:40 PM in reply to: jmiller0621
Thanks jm. I understand your frustration..
Yes, responses like  "I think" and "probably.."  are not helpful from the Autodesk Technical Consultant.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
