Civil 3D Forum
SSA - Inlet Rim Elevations and Weir Flow
4 REPLIES 4
fcernst
3332 Views, 4 Replies
This inlet scematic is tough for Inlet Rim Elevation.
Do I have all of the following Rim Elevation situations correct?
Also, does SSA include all four sides of a grate inlet that is not in a curb setting for its perimeter length in its weir flow calculation?
Fred
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
4 REPLIES 4
Matt.Anderson
in reply to: fcernst
Fred -
The Inlet Rim Elevation would the elevation at the gutter flow line.  The Combination Image shows a depression, so you've labeled the top of curb opening.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
fcernst
in reply to: Matt.Anderson
Thank you for the clarification. Makes more sense.
It just looked like in that schematic that it might have been pointing to that dashed hidden orthoraphic line that goes to the top of the opening.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Fred
In response to your second question... I have asked this before.  Not much help, but you can look at the following thread for some more info:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Stormwater/SSA-Drop-Inlets/td-p/2754376
fcernst
Thanks jm. I understand your frustration..
Yes, responses like  "I think" and "probably.."  are not helpful from the Autodesk Technical Consultant.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
