Civil 3D Forum
SSA Import Option
3 REPLIES 3
wsuswim147
1522 Views, 3 Replies
SSA Import Option
I have an existing SSA model that I have been working on and want to update it with additional information delineated in ACAD (watersheds using the parcels tool). Is there a way to import this additional information from ACAD as a landXML or some other type of file into my existing SSA file. Everytime I try to import, it creates a new SSA model.
Dave
3 REPLIES 3
Matt.Anderson
in reply to: wsuswim147
LandXML import will only import into a new model.
Don't fret - if it is those parcels as subbasins that you are after - save that SSA file and use Merge to pull in your watersheds into the pipe set.
I don't think I have time today to record something, but its simple to demonstrate.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
wsuswim147
in reply to: Matt.Anderson
Great! I figured it out.
Thanks for the lead on the Merge.
I was having the same issue and just saw this post!  Thanks for the tip about the Merge!
Rail Community
