I have an existing SSA model that I have been working on and want to update it with additional information delineated in ACAD (watersheds using the parcels tool). Is there a way to import this additional information from ACAD as a landXML or some other type of file into my existing SSA file. Everytime I try to import, it creates a new SSA model.
Dave
Solved by Matt.Anderson. Go to Solution.
LandXML import will only import into a new model.
Don't fret - if it is those parcels as subbasins that you are after - save that SSA file and use Merge to pull in your watersheds into the pipe set.
I don't think I have time today to record something, but its simple to demonstrate.
I was having the same issue and just saw this post! Thanks for the tip about the Merge!
