I am using SSA to model several pipe networks and am running into a problem with the program results. For example, at storage nodes (ponds), the peak inflow cfs shown in the node properties window is different than the peak flow shown when you select the results icon for that node. Another example is the HGL at a specific node: the displayed HGL in the profile view and in the properties window does not match the HGL shown in the time series you see when you access the results window. Having different HGL results for the same node concerns me and I am not sure which results are correct or used in the Excel results output. Has anyone come across this before? Has Autodesk fixed this bug?
Jason
