Hi, is ther a way to global edit physical & flow properties for sub-basins? I'm bringing in about 130 parcels for catchment area and many will have the same equiv width, impervious %, max min infiltration....
I tried copy paste from excel but it skipped every otherline in SSA.
Your Name
Your Name
Solved by Matt.Anderson. Go to Solution.
Is group edit different than select all >> input>> subbasins? This method still only allows me to edit one basin at a time, with the knowledge I have.
Your Name
Your Name
Group Edit is available when using from PLAN - Edit -> Select All
Great! Your fast this morning
The help file is a good source too
Your Name
Your Name
Looks great, but i have only the Are and toc fields listed. What am i missing?
the other options in the previous image are available if your hydrologic method is set to EPA SWMM under Input>Project Options.
Thanks!
I found out, if I change the hidrology method, than I will be able to group edit the CN. It was just odd, that selecting TR-55 won't let me edit them, but thanks to you, it was resolved.
