I would like to use the ADS Stormtech MC-3500 product on 2 of my current projects, but SSA only contains the SC-310 and SC-740 product. Has anyone found a way to model with MC-3500? Should I contact ADS or can Autodesk provide an update to include the MC-3500 and 4500? Thanks!
Were you able to figure this out? I currently am trying to run the MC 3500 on a project right now and can't find any info on adding the curve data for the 3500 into SSA
Or is there a way to create an excel spreadsheet with the Depth vs Volume info that can be imported directly into SSA? I have the Storage volume info from Stormtech which can be hand typed into the stage curve data table in SSA, but that is only for a single chamber. If I need to add a chamber, I have to go back in and hand type each volume again, run the model, hand type volumes, run model, over and over again until I get the correct amount of chambers needed. That is exhausting and extremely time consuming.
Any Help?
you can create your own stage-volume curve (without hitting the chambers compute button) by copy-pasting data from excel.
stage-volume related to the stormtech chambers are available here (pg 19):
http://www.stormtech.com/download_files/pdf/design_manual_35004500.pdf
