Civil 3D Forum
SSA 2014
5 REPLIES 5
rhschneider
745 Views, 5 Replies
SSA 2014
I run analysis and get following error message:
ERROR 131 : The following links form cyclic loops in the drainage system.
  Analysis began on:  Thu Jul 17 06:56:36 2014
  Analysis ended on:  Thu Jul 17 06:56:36 2014
  Total elapsed time: < 1 sec
There is no listing of links that form the loops.
5 REPLIES 5
wfberry
in reply to: rhschneider
Did you read in the Help Manual about ERROR 131?  It is probably located in the manual somewhere between pages 90-100.
Bill
rhschneider
in reply to: wfberry
Bill:
This is message, but does not list links as indicated on pg 102-103
**** Schneider, P.E.
Project Manager
KAPUR & ASSOCIATES, INC.
10101 Market Street, Ste C20, Rothschild, Wisconsin 54474
main 715-359-9668 Ext. 4005 | fax 715-359-4844 | cell 715-573-1269
www.kapurengineers.com
wfberry
I am not very good at this.  Perhaps if you would attach your .spf file someone can help you.
Bill
Hidden_Brain
Can you attach your SPF file here (you may need to rename it to .txt)?
rhschneider
in reply to: Hidden_Brain
Finally found answer-- Have to set Project options routing method to hydrodynamic.
Rail Community
