AutoCAD Civil 3D - Stormwater
1 Kudo
Post 1 of 6
Shape Factor
273 Views, 5 Replies
09-13-2011 02:00 PM
Does anyone know which value of Shape Factor SSA uses? In my office, before I joined, Hydraflow was being used where Shape Factor was one of the input values. When I used SSA for my project, it didn't ask for Shape Factor value. So I am not sure if it assumes a particular value.
KD
Review Dimenionless Unit Hydrograph.  The Standard 484 is pretty typical, but there are other pre-defined values available
Employee
34 Kudos
Post 2 of 6
Re: Shape Factor
09-13-2011 03:40 PM in reply to: kdave
Matthew Anderson, PE
Product Manager
1 Kudo
Post 3 of 6
Re: Shape Factor
09-14-2011 06:06 AM in reply to: Matt.Anderson
Thanks Matt..!
Member
0 Kudos
Post 4 of 6
Re: Shape Factor
06-27-2012 06:03 AM in reply to: Matt.Anderson
I am not able to find out which shape factor the program is using.  Where do you find that information?  Can it be changed/selected?
WaltBPE
Employee
34 Kudos
Post 5 of 6
Re: Shape Factor
06-28-2012 05:13 AM in reply to: kdave
Walter -
Change the Hydrology Engine to TR-20 and review the Dimensionless Unit Hydrograph. 484.png
The Standard 484 Shape factor is the SCS Unit Hydrograph.
Product Manager
Member
0 Kudos
Post 6 of 6
Re: Shape Factor
06-28-2012 01:54 PM in reply to: Matt.Anderson
Thank you.
It would be nice if the shape factor input was placed with the rainfall selection criteria rather than by tself.
WaltBPE
