Civil 3D Forum
Setting Output Report Precision
0 REPLIES 0
Message 1 of 1
LangloisCVL
216 Views, 0 Replies
I am currently using Autodesk SSA 2012 and I have my units set to CMS as all of my capture curves for my inlet basins are in CMS. For the output report I would like to get the precision of my peak runoff from each subbasin to more than 2 decimal places. I want to do this so I can easily get a more accurate flow to convert to LPS.
I have tried changing the units in project options to LPS but then the model does not run because all of my capture curves are in CMS for my inlets. Is there a way to change the number of decimal places in the output results. If not than the only way to get my accuracy is to go back and change all my capture curves to LPS and run the model. This is kind of a hassle as I need the overall model to be in CMS.
Any help on this subject would be greatly appreciated as I have went through every dropdown menu to change this.
0 REPLIES 0
Rail Community
