Civil 3D Forum
sanitary sewer network Design or just Analyse at SSA?
4 REPLIES 4
hamid.akbari
1021 Views, 4 Replies
Could SSA design a sanitary network or only can analyse the network.
Because before I worked with SewerGems and Sewercad  , at those software by "Analyse" command you could model existing network and software show d/D and other hydraulics parameters. Also, they have "design" option that evenif  you model a network with 200mm pipe for first try and define some design parameters like d/D, Vmax and Vmin, slope,then software change (design) the pipes based on parameters.
Can I have this option at SSA , I mean can I define some diameter for pipes from 200mm to 800mm and SSA design and assign an appropriate diameter on each pipe (at least equal and more than previouse pipe and based on min/max of velosity, slope, cover) and appropriate manhole size for those?
Hamid
4 REPLIES 4
nggeotex
in reply to: hamid.akbari
Look into www.insince.com. It will solve all your needs.
Joe-Bouza
If storm cad resizes pipe SSA must. Not to mention the migration settings to and fro Civil3d implies this is what it does.
Does it tell you a better route? Probably not.
But I'm fairly confident it will size your pipe accordingly
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
nggeotex
in reply to: Joe-Bouza
As told earlier, software InSINCE gives you a better route also. It does route optimization, efficient designing and complete cost estimation with drawings/profiles etc. Request for a demo and try it. Look into www.insince.com. Can request for a demo at neeraj@insince.com.
nggeotex
Dear Hamid,
Try InSINCE. It will do all hydraulic designs with whatsoever constraints like pipe dia, slope, velocity etc you provide. Spare a minute to see the website which appears very simple but is the best tool available in t he world for designing. It will give you the best route as well for sewerage network.
Neeraj
Rail Community
