Could SSA design a sanitary network or only can analyse the network.
Because before I worked with SewerGems and Sewercad , at those software by "Analyse" command you could model existing network and software show d/D and other hydraulics parameters. Also, they have "design" option that evenif you model a network with 200mm pipe for first try and define some design parameters like d/D, Vmax and Vmin, slope,then software change (design) the pipes based on parameters.
Can I have this option at SSA , I mean can I define some diameter for pipes from 200mm to 800mm and SSA design and assign an appropriate diameter on each pipe (at least equal and more than previouse pipe and based on min/max of velosity, slope, cover) and appropriate manhole size for those?
Hamid
As told earlier, software InSINCE gives you a better route also. It does route optimization, efficient designing and complete cost estimation with drawings/profiles etc. Request for a demo and try it. Look into www.insince.com. Can request for a demo at neeraj@insince.com.
Dear Hamid,
Try InSINCE. It will do all hydraulic designs with whatsoever constraints like pipe dia, slope, velocity etc you provide. Spare a minute to see the website which appears very simple but is the best tool available in t he world for designing. It will give you the best route as well for sewerage network.
Neeraj
