Civil 3D Forum
Safety Factor in SSA
1 REPLY 1
dinaw
398 Views, 1 Reply
I found a "Safety Factor" in SSA under Variable Timestep in Analysis Options. It has been set to 75%. How does this affect the calcs?
1 REPLY 1
Matt.Anderson
in reply to: dinaw
This only effects the Hydrodynamic routing calculations.  It is used to ensure calculation stability by adjusting the time step so that pipe/channel depths do not change excessively between time step calculations.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Rail Community
