I found a "Safety Factor" in SSA under Variable Timestep in Analysis Options. It has been set to 75%. How does this affect the calcs?
Solved by Matt.Anderson. Go to Solution.
This only effects the Hydrodynamic routing calculations. It is used to ensure calculation stability by adjusting the time step so that pipe/channel depths do not change excessively between time step calculations.
