Civil 3D Forum
SAA 2014 HELP function not work
3 REPLIES 3
263 Views, 3 Replies
Hi Guys,
When I tried to click "Help" botton on SAA 2014, nothing happened. I saw there is shortcut "Storm and Sanitary Analysis User Guide" under programs\autodesk\autodesk. Is that the same one as clciking the help button. if yes, any way to get the help button fixed?
David
3 REPLIES 3
wfberry
Yes, I am sure it is.  It will open up to about 540 pages in pdf format, save it to a folder and make a shortcut to desktop.
Bill
Matt.Anderson
As Mr. Berry points out, yes, the Help is the User Guide PDF.  In needs an Adobe Reader to display correctly, and can easily be minimized into the lower corner of your screen.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
in reply to: Matt.Anderson
Bill,
Thanks for the confirmation!
Matt,
Thanks for the tip.
and one more question here. Only SSA has this help issue? As I known, most apps help will open MS help window and show the contents.
Rail Community
