Am working in River Analysis dwg and go to save and get message "One or more objects cannot be saved to the specified format."
What's the deal?
I've had this happen and never found a good answer. I had to restart my drawing from scratch, I'm sad to say. I suspect it had something to do with sheet set manager, but couldn't verify.
Good luck
If you feel that this is related to River Analysis, please submit the feedback to the labs.civil3d.river email address.
DECEMBER 2013
This is happening again. Began saving after every command and when I created 1st river section got the message. Very frustrating!!
I have seen others during my AU lab get the same error, but I have not been able to reproduce the situation that produces the issue.
I would suggest opening a support request. In the request, we will likely need to know what other Autodesk software is installed to determine what is causing the conflict and error message.
I had this problem pop up recently. I was determining flow lengths in the section description, and found that it saved fine, until i revised a flow length. then the "one or more objects cannot be saved in the specified format" thing popped up. So I think it might have to do with some conflict created by revising parameters in the program.
esto te puede servir @rhschneider @mgonzalez_symetri @wesley.... es una gui de uso....por favor dame un kudo...
uno mas actual..... @rhschneider
