I can't seem to change my current reach with the pulldown menu in the ribbon. It will select the reach, but doesn't make it current. If I restart Civil 3d it defaults to the first reach and through the reassign section command I can flip to other reaches. However, if I do this to switch to a reach with no sections, I get an alert saying there are no sections and unable to assign cross sections.
Is my work flow incorrect? I created all of the reaches I needed first and then created the junctions second. My plan was then to switch to the current reach and create my cross sections. Should I have created all of my cross sections first and then reassigned them to individual reaches?
