Civil 3D Forum
River Analysis Runtime Error in C3d 2012
16 REPLIES 16
Message 1 of 17
JOHNHAAG6922
1469 Views, 16 Replies
I get the following error after pressing the "Compute Analysis" ribbon button,"Runtime error 429.  ActiveX component can't create object".  Anyone else having this issue?  Is there a fix?
I'm using the sample projects drawings in the River Analysis folder.
John J. Haag, P.E.
Haag Engineering Consultants, Inc.
16 REPLIES 16
Message 2 of 17
Did you save the drawing to a location you have access writes too?
What O/S?
Have you tried uninstalling and reinstalling?
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 3 of 17
Yes - I opened and saved file on a desktop test folder with access rights.
I did uninnstall and reinstall twice.
Please see attached screen capture shots for problems and system info.
thanks,
Haag
John J. Haag, P.E.
Message 4 of 17
BTW...I found the attached error log file if it helps.
thanks,
Haag
John J. Haag, P.E.
Message 5 of 17
JOHNHAAG6922
in reply to: JOHNHAAG6922
I forgot to mention that the hydraulic calculator button works but anything associated with the compute analysis process.
Haag
John J. Haag, P.E.
Message 6 of 17
Which file are you attempting to run?  How did you launch River Analysis?
Can you email labs.civil3d.river@autodesk.com?
Product Manager
Autodesk (Innovyze)
Message 7 of 17
Thanks for the response!  I launched using the desktop icon and am trying to run the "Verona" file that was included in the River Analysis sample folder.  I am attaching it to this post.  I'm having the same problem with other files too.  the error dialogue box and error log file indicate that the program can't create "RDT" (raster data table???).  I saved the Verona file to my desktop test folder because the original in the sample folder is read only - i didn't modify anything in this file other than save it to new location using C3d 2012..
thanks,
Haag
John J. Haag, P.E.
Message 8 of 17
Have you tried launching the shortcut with admin rights? Worked for me when I was having the same issue.
Message 9 of 17
If anyone encounters this error try the following:
Copy the Steady.exe file from:
C:\Program Files\Autodesk\Project River Analysis 2012\Bin
to
C:\Program Files (x86)\Autodesk\AWA\Support\Tool
This should effect only those 64bit machines.
If you are missing that file from the 32-bit location, reply and make note of the User Account Center setting when you installed River Analysis.
Product Manager
Autodesk (Innovyze)
Message 10 of 17
Worked like a charm!
Thanks!
John J. Haag, P.E.
Message 11 of 17
jalneal
I have the same issue as stated above, but the fix Matt is suggesting didn't work on mine - Steady.exe was actually already in the Program Files(x86) location mentioned.   I am on Windows 7 x64.
Running the application as administrator does work.  Running as a normal user is generating a system event that states the machine default permissions settings don't grant local activation permission for the Com Server then states the APPID and CLSID.
I have tried to change COM permissions for this app, but they appear greyed out, even when running as an administrator.  Will probably try to tinker with this again soon.
Alan Neal, P.E.
Autodesk Infrastructure Suite Premium 2012/2013
Windows 7, x64
Xeon E31225 w/ Quadro 600
Message 12 of 17
Matt.Anderson
in reply to: jalneal
jalneal -
You may try this location: C:\Program Files (x86)\Autodesk\AWA\Support\Tools\
Product Manager
Autodesk (Innovyze)
Message 13 of 17
jalneal
in reply to: Matt.Anderson
That worked - had to restart the computer to get it to work, but that solved it.
Alan Neal, P.E.
Windows 7, x64
Message 14 of 17
subpartner
In my case it doesn't work. does being just a user makes it impossible to do the computation in RAE unlike you are the administrator?Smiley Sad
Message 15 of 17
para máquinas de 32bits ¿como se soluciona el error?
Gracias
Message 16 of 17
Even after copying Steady.exe to the x86 program folder as suggested. I continue to get the message below.
Does anybody has nay suggestions/
Adhir Agrawal, P.E.
Message 17 of 17
erki
Hello!
I have a little problem with the  Project River Analysis 2012 Extension for Civil 3d (2012). I imported data from HEC RAS and then I tried to compute analyse but then the error  "Runtime error 429.  ActiveX component can't create object" came up.
I have uninstalled and reinstalled the program many times. Program still dont work.
Also I have copied the Steady.exe file from Program Files\Autodesk\Project River Analysis 2012\Bin to Program Files (x86)\Autodesk\AWA\Support\Tool. Still dont work.
What is the problem? What should I do?
I have Windows 7 x 64.
Looking forward to Your reply!
Erki K.
Kobras AS
Project Manager, Designer
Rail Community
