Hi
We have recently bought Civil 3D suite along with SSA. We have created the network by assigning a surface model in Civil 3D and imported to SSA for analysis. We are intending to change the node elevations during analysis. When using the command 'Assign Node Invert Elevations', the invert elevations are changed and related rim elevations changed too. Is there any way to delink the rim elevations for using this command so that we still have the orginal ground surface levels retained. Please suggest on how to delink the rim elevations during the creation in Civil 3D or during analysis within SSA. Also is there any way if we can import the original ground surface elevation from Civil 3D subsequent to the analysis with in SSA to compare the changed rim levels with the original ground elevations.
Grateful for help!
Dr K Sravan Kumar
Aarvee Associates
currently im using SSA 2015... this 'Assign Node Invert Elevations' still change the Rim Elevation... Any solution to this?
Joe Bouza
