Hydraflow Storm Sewers Extension 2008 has been driving me nuts for the past couple of days. I finally realized what it was doing but I am not sure why. Try this on any of your 2008 files and see if you have similar results.
Depending on which tab I am on when I run a system I get varying results. Run an analysis w/design, starting the HGL at normal with the ‘plan’ tab current and view your DOT results. Pay particular attention to the Total Flow, System Tc and Intensity at the end line.
Make no changes to the system but make your ‘Pipes’ tab current. Re-run the system again using analysis w/design, starting HGL at normal and see if your Q, Tc, and Intensity changed.
The Plan tab results produce higher flow rates due to a shorter Tc and slightly higher intensity.
The Pipes tab produces lower flow rates with a higher Tc and lower intensity.
Can someone explain this one to me?
Jon
IDSP '15 SP3 / '16 SP2
Dell Mobile Precision 7720 - Core i7-7820HQ / Win 10 / 32GB Ram / SSD / Quadro M1200
