can someone please tell me how i can input a rating curve in SSA? to be more specific, I am dealing with a vendor who manufactures a bouyant device that maintatins a constant flow rate thru the basin outlet structure over an extended perios of time. iun Hydraflow, I can use the user defined flow in pond to define the flow out per the rating curve, but is there a similar function in SSA?\
i should apologize upfront that i did not search the forums to search for an answer for a similar question, but a google search has not yet returned anything favorable. I appreciate anyone who can set me in the right direction.
If I understand your question correctly, I believe you could insert an outlet and apply the rating curve to it.
