Can Stormwater calculate pressurized pipe networks in a similar way to Epanet?
Solved by Matt.Anderson. Go to Solution.
I do not know what Epanet does exactly but I can tell you Stormwater or SSA does ZILCH for pressure systems.
Bill
Hugh -
SSA has pumps and forcemain components that work like EPA-SWMM. EPANET is water distribution calculations.
Thank you to both of you for your helpful replies.
Since I need Epanet for pressure systems I will look into using Epa SWMM with the hope that there are similiarities in the programs making them easier to learn. I intend to return here eventually to report on success / failures of trying the programs.
