AutoCAD Civil 3D - Stormwater
Member
n.bokma
Message 1 of 8 (977 Views)
Multiple inverts from junction/inlet in SSA
977 Views, 7 Replies
01-24-2013 06:12 AM
Good day everyone,
I am working on drainage for a median storm sewer, culverts and ditching for a large freeway expansion project.  I have median storm sewers running down my entire roadway (about 5kms).  I have manually inputed the upstream and downstream elevations of the pipes in SSA, but when these pipes are connected to an inlet or junction, I only have the option of selecting one invert elevation for each structure (I am actually using a lot of catchbasin manholes in this project, which I am unsure of SSA's ability to model).  I have multiple drops of varying elevation differences throughout the project, with some of these inlets/junction requiring drop structures due to the large difference in elevation change.  How do I properly model this in SSA?
I like that idea.  After looking at the SSA manual, I think that the inlet invert elevation is the sump or lowest possible "base" elevation of the structure, and then you can further define the conveyance link elevations higher than the "base" elevation (This is what I can understand from the SSA help PDF, page 251, screenshot attached).
- Nathan
wfberry
Message 2 of 8 (970 Views)
Re: Multiple inverts from junction/inlet in SSA
01-24-2013 10:10 AM in reply to: n.bokma
n:
I have done very little in SSA but PERHAPS you could slap a JUNCTION just on the downstream side of the "real" structure and model it that way by setting your outflow elevation in the junction.  (There may be a setting somewhere to change the inverts in the manhole, but like you, I have not found it.)
Bill
Member
n.bokma
Message 3 of 8 (968 Views)
01-24-2013 10:18 AM in reply to: n.bokma
I originally set up my project like that, but then I realized that there is onyl 1 invert elevation option for both inlets and junctions, so I just went with the inlets.
Does the invert elevation in the inlet/junction structure just refer to the bottom of the structure (or maybe the sump), and then further information needs to be inputed in the conveyance links window?
wfberry
Message 4 of 8 (962 Views)
01-24-2013 11:56 AM in reply to: n.bokma
I was thinking that your conveyance link could be about 4' which, in my area would represent the distance across a normal manhole.  So outlet to inlet (junction) elevations could certainly represent your drop in height.  Just a thought.
Bill
Member
n.bokma
Message 5 of 8 (959 Views)
01-24-2013 12:03 PM in reply to: wfberry
- Nathan
wfberry
Message 6 of 8 (955 Views)
01-24-2013 12:10 PM in reply to: n.bokma
I really think that picture is misleading.  Surely the catch basin elevation also represents the inverts of both of those pipes.
Bill
rdbauer50
Message 7 of 8 (938 Views)
01-25-2013 11:12 AM in reply to: wfberry
Nathan-
According to SSA 2012 PDF page 234-235,
"Invert Elevation
This entry defines the bottom elevation of the junction (ft or m) above a
common datum. See Figure 7.11 for an illustration of this value."
I was wondering the same thing at one time. It is just the bottom of the structure and has nothing to do with the pipe inverts. Hope this helps.
Rich Bauer, MS, PE, SIT, M.ASCE
Engineering Department Manager
RB & Associates Consulting, Inc.
www.rb-associates.net
rdbauer50
Message 8 of 8 (936 Views)
01-25-2013 11:16 AM in reply to: rdbauer50
Just to clarify, I know you were talking about the catchbasin invert elevation, but the one I posted, I thought it described it better, but it would mean the same thing.
