I'm very new to Civil 3D.
I've created a network of my stormsewer (which means the stormsewer lines are all on different streets) and added the inlets to my street profiles.
How do I get the profile structure labels to reflect the stationing from the street alignments?
Thank you!
Solved by rdbrennan48. Go to Solution.
If you go into the structure properties, under part properties, general, referane alignment. You will have to have both the storm sewer model and the alignment you are using shortcutted into the drawing.
