AutoCAD Civil 3D - Stormwater
Active Member
kahligsm
Message 1 of 3 (165 Views)
Inlet Control not Checked for Pipes?
165 Views, 2 Replies
09-11-2012 10:15 AM
After testing a simple culvert and pipe, it appears that inlet control is not checked for pipes.  Does this mean that I have to model all storm sewers in a network as culverts just to check inlet control?
Employee
Matt.Anderson
Message 2 of 3 (164 Views)
Re: Inlet Control not Checked for Pipes?
09-11-2012 10:22 AM in reply to: kahligsm
In Hydraflow Storm Sewers, the Design Codes have the option to check Inlet Control.
In Storm and Sanitary Sewers, pipes can be set to operate as Culverts.
Matthew Anderson, PE
Product Manager
Active Contributor
rdbrennan48
Message 3 of 3 (154 Views)
09-12-2012 05:45 AM in reply to: kahligsm
If you model a conveyance link in SSA as a pipe will it check for both inlet and outlet control?
Post to the Community
New Post
Need installation help?
