As a newbie to SSA I am having some problems with my model to work. Specifically with the bypass link. I am getting the error 600 mesage for several outlets (12, 14, 21, 22, & 28). I have tried the irregular channel but its not working. I have attached the .zip file for the model. Hopefully there is a kind soul out there that can point me in the right direction...
Thanks!!
I know enough about this program to start it. So here goes, according the manual (Error Messages start on Page 95 in the 2015 Manual) ON GRADE Inlets need two outlets.
For what it is worth, I changed your listed outlets to SAG and they ran just fine. This is not to say that you must run them as SAG. You must add a stormwater pipe as well as the ByPass link.
Bill
Bill,
Thanks... I ran the bypass links "directly" to the downstream inlet. Still no luck. I can run it as a sag but tthats kind of cheating isn't it. 🙂
Yes, but you still need the regular pipe as well. If you don't need a pipe, then it is not a bypass.
I hope I read what you did correctly.
Bill
I am having trouble with bypass links as well. I have pipes running between the inlets with the correct inverts, as well as links connecting the inlets (these are supposed to serve as bypass links) with the inverts set as the inlet rim elevations. I also made sure each inlet has the bypass assigned in it's properties. I'm still receiving this error: "ERROR 600 : On grade Inlet CB1 does not have two outlet links. At least one stormwater sewer pipe and a bypass gutter link must be defined."
