The toggle button for upstream to downstream is really in the wrong location because of that fact. It only applies to the next step of drawing your next pipe.
There is a Change Flow Direction command (see the PIpes -> Change Flow Direction) that allows you to apply the change from upstream to downstream after the fact.
Matthew Anderson, PE
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
