I have all my storm drain designed for a large development. There are approximately 10 network files.
I have gone back to tweak some of the designs and when I select RUN for analysis and select OK to analyze, Hydroflow exits. Completly goes away.
Can't analyze any stormwater in my project. Running v10.3 Hydroflow.
Any suggestions? Thank you
Solved by aspencer. Go to Solution.
As requested, here are some files.
I had to change the file extension to .txt because board will not allow upload of .stm files. You will have to change the extension back to .stm
I used your file with Hydraflow Sewers Extension 10.3 and it gave a "Warning" but it did run.
Bill
Warning Attached
Thank you very much for trying. What was the warning? Perhaps I can fix it blindly.
This is very strange. It worked fine for months and just started this.
Best Regards
as
I tried them on my associates workstation and everything ran fine. Must be on my computer. I will let you know what I find out.
We have telephone support with Eaglepointe. I called them and they worked with me to determine that the problem was caused by this directory somehow being set to read-only.
C:\Users\aspencer\AppData\Local\Autodesk\C3D 2014\enu\HHApps
Once we fixed the folder settings, everything ran fine.
The mystery is how did the settings get changed?
Thank you for all your replies.
