Civil 3D Forum
Hydroflow Crashes/Exits on Compute System>OK
6 REPLIES 6
aspencer
644 Views, 6 Replies
I have all my storm drain designed for a large development.  There are approximately 10 network files.
I have gone back to tweak some of the designs and when I select RUN for analysis and select OK to analyze, Hydroflow exits.  Completly goes away.
Can't analyze any stormwater in my project.  Running v10.3 Hydroflow.
Any suggestions? Thank you
6 REPLIES 6
wfberry
in reply to: aspencer
Perhaps if you loaded a file or two here, someone could take  look at it.
Bill
aspencer
As requested, here are some files.
I had to change the file extension to .txt because board will not allow upload of .stm files.  You will have to change the extension back to .stm
wfberry
I used your file with Hydraflow Sewers Extension 10.3 and it gave a "Warning" but it did run.
Bill
Warning Attached
aspencer
in reply to: wfberry
Thank you very much for trying.  What was the warning?  Perhaps I can fix it blindly.
This is very strange.  It worked fine for months and just started this.
Best Regards
as
aspencer
I tried them on my associates workstation and everything ran fine.  Must be on my computer.  I will let you know what I find out.
aspencer
We have telephone support with Eaglepointe.  I called them and they worked with me to determine that the problem was caused by this directory somehow being set to read-only.
C:\Users\aspencer\AppData\Local\Autodesk\C3D 2014\enu\HHApps
Once we fixed the folder settings, everything ran fine.
The mystery is how did the settings get changed?
Thank you for all your replies.
Rail Community
