AutoCAD Civil 3D - Stormwater
Active Member
agorodetsk
Message 1 of 4 (539 Views)
Hydraflow
539 Views, 3 Replies
01-17-2013 02:46 PM
I opened Hydraflow Sewer Extensions and created a project. I was able to save it and open repeatedly without problems. I opened open project dialogue window here I copied and renamed a copy of the project file. When I tried to open either the original file or the renamed version - Hydraglow shuts down. The project file has attached dxf file as abackground. (see attached). I hate to lose a day of data entering given my tight deadlines - any help would be greatly appreciated.
I run Civil 3d 2013 on Win 7 64 pro. I have attached file
Thank you.
Alex Gorodetsky, P.E.
Valued Mentor
fcernst
Message 2 of 4 (515 Views)
Re: Hydraflow
01-19-2013 10:03 AM in reply to: agorodetsk
I don't see the attachment? I thought I would just give it a try on my system.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
www.ernstengineering.com
Active Member
agorodetsk
Message 3 of 4 (507 Views)
Re: Hydraflow
01-20-2013 09:50 AM in reply to: fcernst
Thank you, but I just dumped a day of work and generated a new file. On another topic: Did you ever model a bolted manhole in Storm Sewers? I got an advice, though I  have not tried it yet, to set upa rim elevation high enough to keep the water from overflowing, which sounds kind of reasonable to me.
Any thoughts?
Thank you again.
Alex Gorodetsky.
Valued Mentor
fcernst
Message 4 of 4 (503 Views)
Re: Hydraflow
01-20-2013 09:55 AM in reply to: agorodetsk
10-4...
Not in Hydraflow, but yes in StormCAD I have in the past, to make sure uplift force will not be excessive on the manhole framework.
Fred Ernst, PE
C3D 2015 SP2
Ernst Engineering
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
