What calculation method did you use? Is your pipe travel time correct?
Is your pipe velocity high?
Feel free to email the file to me - anderson at jaseng dot com and I
will take a look.
Matthew Anderson, PE
niranjan61 wrote:
> We are running Hydraflow Storm Sewers - 2008, My co-worker designed
> storm sewer system using this version and printed report. Now I need
> to print/export results into different format per city requirements.
> To print report this program must re-run, it seems that it is almost
> impossible to get same results out from the same file? having several
> options to run, it is even more difficult. I wonder why the saved file
> do not save run information and results? How do i get same results
> from saved file? Recently we installed AutoCAD civil3d and it does
> same thing. I tried to upload file, but getting error, even after
> chnaging file .stm file ext to .txt
