Civil 3D Forum
Hydraflow Express Culverts - Negative Invert Elevation
2 REPLIES 2
913 Views, 2 Replies
I am analysing a culvert in a tidal zone which has an outlet invert level below the normal tidal range. The invert level of the culvert outler is -0.520m, however Hydraflow Express Culverts will not allow a negative invert elevation to be entered.
Does anyone know a way around this?.
Regards
Lar Hughes
2 REPLIES 2
Matt.Anderson
Lars -
The workflow would be to move the datum up such that 0 m is now 10m and all of the elevations are postive.
It would be advisable to use Autodesk Storm and Sanitary Analysis for tidal culverts.  It does not have the negative elevation limitation and can adequately solve tidal culverts with flap gates.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
in reply to: Matt.Anderson
Matt
Thank you very much for your reply. I will try and model this culvert in SSA. Do you know if SSA will output similar results for a culvert as Hydraflow Express - i.e. HGL's, Hw Elevation, Hw/D, results schematic and wheter the culvert flow regime is inlet or outlet control.
Lar
Rail Community
