Civil 3D Forum
Hydraflow, Drainage area output on FL-DOT report
0 REPLIES 0
Message 1 of 1
gwieger
372 Views, 0 Replies
I have a catchment created that has the runoff coefficient entered into it in cad and I bring it over to Hydraflow to work on the design. In the add/edit dialog box  for that structure the drainage area and the runoff coefficient are already input.
When I select to have the report in FL-Dot format, after running it of course, the drainage areas are zero because the report is pulling from the composite runoff values, which there are none. Is there a way I can have this auto populated using the single value I already brought over? C1 is the value from the catchment with C2 and C3 remaining zero. Instead of manually entering the value that is already in the flows box into the composite runoff box.
Thank you
0 REPLIES 0
Rail Community
