Yes, you discovered the limititation of Civil 3d and the cross-sections stationing by way of polylines. (I didn't look at the image until this morning and yes I see the issues).
One item that may help is added you polyline sections as sample lines to you alignment. When you do that, your sample line, when selected, will show you "where" it assumes your alignment station to actually occur. if you manipulate the section station grip and drag your sections grips, I think you can get it back to the way you want it.
Cross-sections for Hydraulics should be orthanginal to flow, not the alignment.
Maybe I'll blog this next week on civil3d.com...
<dlmanning> wrote in messageTo
href="news:6115794@discussion.autodesk.com">news:6115794@discussion.autodesk.com...
clarify, the way the engineer drew the cross sections parallel to each other
is the correct way? Is that what orthogonal to flow means? And here you said
"One item that may help is added you polyline sections as sample lines to you
back to the way you want it." Are you suggesting to create samples at the
appropriate station and then adjust the grips to change the orientation of the
sample and that this would fix the afore mentioned problem of just creating
sections from polylines?
in the HEC-RAS geometry editor, click EDIT>MOVE, then move one reach with the tiny blue grip to snap onto the other reach, the software will prompt you to split the reaches and create a junction. double check the rech lengths to the junction under junction editor.
Good afternoon,
I have a question regarding exporting sections from CIVIL into HEC-RAS that has to do with wrong positioning.
I'm still quite new to this software but as far as I know, HEC-RAS assumes the zero-station (x-axis) on the left side of the graphic (IMG01 - attached).
I was wondering if there is an easy way to import the sections from AutoCAD Civil, having the zero-station on the river axis, ie in the middle of the graphic with a negative (left) and positive (right) sides (IMG02 - attached).
What I was naively doing so far was inserting point by point with its station and elevation values, which consumes a lot of time.
I hope I've explained myself clearly, thank you in advance for your time.
Regards.
DS
DS -
The original design of the tool expected the user to use HEC-RAS to flip both the coordinates of the reach and cross-sections. HEC-RAS supports that workflow in the geometry editor.
[Note that my prior comment in this thread occured when I wasn't a Autodesk employee... but now all my prior posts are now tagged as employee. ]
