I just received a new HP Z800 Workstation with Civil 3D 2011 and Win 7 (both 64-bit) I am getting these unhandled eception error messages when I launch the Hydroflow Hydrographs extension. Has anyone else encountered this problem?
Mike
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at Hydrographs.REACH.INFLOW1_SelectedIndexChanged(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
at Hydrographs.REACH.REACH_Activated()
at Hydrographs.REACH.REACH_Load(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at Hydrographs.mainmen1.MNUREACH_Click(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Hydrographs
Assembly Version: 8.0.2155.0
Win32 Version: 8.0.2155.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202011/HHApps/Hydrographs.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Hydrographs.resources
Assembly Version: 8.0.1439.0
Win32 Version: 8.0.1439.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202011/HHApps/en-US/Hydrographs.resources.DLL
Microsoft.VisualBasic.Compatibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
C1.Win.C1FlexGrid.2
Assembly Version: 2.6.20083.387
Win32 Version: 2.6.20083.387
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202011/HHApps/C1.Win.C1FlexGrid.2.DLL
C1.Win.C1FlexGrid.Classic.2
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Civil%203D%202011/HHApps/C1.Win.C1FlexGrid.Classic.2.DLL
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Hi mvanarsdale-
Are you getting any other error messages besides the JIT error? Does this happen with the other Hydraflow applications? Did you install Civil 3D under your Windows account or did IT do so under an Admin or IT account? If so please see this blog post as it may resolve your issue: http://beingcivil.typepad.com/my_weblog/2009/08/installation-error-invladi-installation-program-endi...
Thanks for the post, I checked the blog you suggested and the files are there and seem normal. Could it be a .net issue? I am current running version 4, (Windows 7, 64-bit)
Mike
