Civil 3D Forum
File Won't Open
4 REPLIES 4
cwitzel
783 Views, 4 Replies
File Won't Open
We have five files created with either Storm Net or SSA 2011.  The files were last worked on last year.
We are unable to open any of the five files, although we are able to open other projects created with older versions.
The location of the projects has changed, but that is the only thing.  I have attached one of the projects to see if anyone can open them.
Civil 3d 2012 64 bit
Windows 7 64 bit
Conan Witzel
Conan Witzel
Civil 3d 2021 SP1.1
Smoking BOXX Apex 2 Workstation
4 REPLIES 4
Matt.Anderson
in reply to: cwitzel
Conan -
That's odd, but the file opens without issue (it's just missing the undlay)
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
cwitzel
in reply to: Matt.Anderson
Matt,
No the program crashes while opening.
I can open the file using StormNet 4.4.08896 and it did give me a warning about the underlay, but it does open and reports the following error:
Error Report for File pre
Unrecognized keyword (LINK_OFFSETS) at line 31:
[OPTION]
LINK_OFFSETS          DEPTH
Unrecognized keyword (MIN_SLOPE) at line 32:
[OPTION]
MIN_SLOPE             0
I then saved as another file name and tried to open with SSA.  This time I was able to get SSA to at least generate a Bug Report (attached as it couldn't be sent)  It may have something to do with the errors reported by StormNET.
Conan Witzel
Conan Witzel
Civil 3d 2021 SP1.1
Matt.Anderson
Conan -
I can not reproduce.  The file opens in both 2011 and 2012 on Win7 64, and the analysis runs without issue.  The file does NOT appear to be corrupt.
Let's rule this out prior to reinstallation.  Locate the SSA.ini file in the ProgramData directory and delete it. C:\ProgramData\Autodesk\SSA 2012.
Relaunch SSA and open the file.
Product Manager
Autodesk (Innovyze)
cwitzel
Matt,
It appears it has something to do with the location.  The original location has a path of just over 100 characters
I moved it to my desktop and it opened fine.
Conan Witzel
Conan Witzel
Civil 3d 2021 SP1.1
Rail Community
