I have found that the Export to HECRAS tool within 2010 Civil3D creates an incorrect geometry file. The river/reach line is drawn in the reverse direction, the left and right downstream distances are reversed, and the cross-section stations are reversed.
I created a VBA macro within Excel that corrects the river/reach line and downstream distances in the HECRAS geometry file (*.geo). A new, corrected file is created with "_rv" added to the file name (*_rv.geo).
Additional notes to creating geo files:
1) You must still reverse all cross-section stations within HECRAS.
2) In Civil3D, you must setup the alignment starting downstream to upstream. Setup left and right banks looking upstream.
3)To force floodplain lengths to be calculated correctly, place banks in the middle of floodplain.
Attached is an Excel spreadsheet that contains the VBA macro.
Scott Stoneman
thanks for replying Scott, i originally meant to say the upstream and downstream x-sec for the culvert (please see attached screenshot). you know how when you are entering culvert data, for your deck fill, you have your stations from the bounding cross sections, but the corresponding elevations from the road crown? the problem is that even if my cross section line and the deck section line are the same length, i cannot simply copy paste the elevations, because the deck may be at a skew to the anticipated flowpath. i am thinking of a way (by using feature lines, projecting objects etc) to somehow have the elevations "sucked out" of the road crown.
I would like to thank you for your macro. It helps me a lot. But I have a different problem . I have Civil 3d 2010, im using export to HECras, but have problem with stationary. I have first crosssection starts with 0 and the last is the second, betwin is evrything ok? Whats seems to be a problem, Ive tried with different project but its the same. Anyone have that problem ? Sorry for my bad english. THx
