I click the perform analysis button, I recieved the following error "ERROR 544 : Unable to perform analysis, - precipitation time series does not exist". So I start back tracking to ensure I completed everything, my rain gage (with my local time series) is connected to all my subbasins. I deleted the rain gage and try default time series, no luck. Any insight would be very helpful.
Steve
Solved by stobler. Go to Solution.
Hi Steve,
Posting the SSA file you are working with would allow anyone to analyze what is going on easier.
Thanks!
Figue out the problem, under Analysis Options - Tab Storm Selection - Select Storm - was used Rainfall Time series (incorrect), change to use Assigned rain gage (s) (correct). It was able to analysis the storm event.
