AutoCAD Civil 3D - Stormwater
New Member
rockne
Message 1 of 5 (264 Views)
Error 517 in SSA
264 Views, 4 Replies
10-25-2012 07:04 AM
I'm getting the following error:
ERROR 517 : Error in reading TR-20 project data.
but when I compare my raingage input to the one in samples it appers to be correct. Is there someplace else I need to be checking? The file is attached if that will help.
Issue is not related to raingage or Time Series. Go to Input->Dimensionless Unit Hydrograph and remove the values
amit1304in
Message 2 of 5 (255 Views)
Re: Error 517 in SSA
10-26-2012 02:06 AM in reply to: rockne
Problem is related to your Dimensionless Unit Hydrograph. Values in Dimensionless Unit Hydrograph should be in between 0(zero) to 1. Change the values in Dimensionless Unit Hydrograph it will solve your problem
Amit Garg
New Member
rockne
Message 3 of 5 (249 Views)
10-26-2012 05:48 AM in reply to: amit1304in
Thank you for your response. However, I didn't input the unit hydrograph, I checked the SCS Type II and changed the 4" intensity to a 4.08in. per the local requirements. If I go back to the default or even to a different county I still get the same error. If I deleate the raingage and recreate it using the defaults I get the same error. Were you able to get it to run?
amit1304in
Message 4 of 5 (246 Views)
10-26-2012 06:13 AM in reply to: rockne
amit1304in
Message 5 of 5 (241 Views)
10-26-2012 07:06 AM in reply to: rockne
Please find the attached model which is ruuning. I just removed the Dimensionless Unit Hydrograph and chaged the WSEL for one storage node
