If I have a pipe network in a drawing and pick Edit in Storm and Sanitary Analysis (2015) SSA opens and asks if it's a new project or existing. Pick new and sometimes the drawing comes in but most of the time it does not.
For the life of me, I can't figure out what is causing this function to work so sporadically.
Any ideas will be appreciated greatly. Thanks to all,
Tim
Tim:
I tried it on a small job I did last year. At first I did not think it had come in, but there was a tiny spot on the page that I had to zoom in on. Finally it showed.
Keep in mind that I rarely use SSA. It came into SSA as a rational storm network but it was a sanitary network with two short trunk lines. The interesting thing was that the manhole on the upper end of Sewer A was connected to the upper end of Sewer B with a link.
Bill
I just tried this in 2014 - 3 times with the same CAD file.
The window popped up to select which networks. I selected the ones I wanted and tried both new and existing. All I got was no items exported and Access voilation at address 0176704B in module Storm Sanitary.exe Read of address 00000000
I guess nobody ever uses this software.
I gave up on Storm & Sanitary and opened in Storm Sewers. MOST of the catchment area, Coefficient, and TC info came through. It was better than the complete lock up with SSA 2014.
I have no idea why some of the catchments did not link to the structures.
The EditinSSA function from Civil 3D requires the 32-bit Civil 3D object enabler to be installed on Civil 3D during the Civil 3D installation.
The goal was to bring the networks selected, and load the Civil 3D drawing as the background object.
Anne -
Catchment attachment to structures in CIvil 3D isn't related to the object enabler. The Catchment is attached to a structure and is transferred to STM.
Confirmed Defect:
It doesn't work in 2016. You would have to try an earlier version or
open in Storm Sewer; which has some issues, but mostly gives the correct answer. Do a quick inlet head water analysis check and what the system time.
You can sort of import Storm Sewer files in SSA. The gutter bypass doesn't come through, but the pipes and catchments seem to.
