I am trying to change the dimensions of a concrete box culvert headwall in C3D. The dimensions of my box culvert are 6'x4', but I can't seem to get the headwall dimensions to change to fit the box culvert. The dimensions of the headwall stay at the default, which is 2'x2'. I have tried changing dimensions in the structure properties as well as part builder. I am using C3D 2010.
Thanks for any help,
Dylan Douglas
Dylan -
You should be able to ADD that part to the Part List to the dimensions you need. If you have opened Part Builder and added a specific structure size, you will likely need to regenerate the catalog, and insert that sized part into your part list, and SWAP the existing part with the newly created structure.
