When importing STM file, only outfalls come in. In Pipe Networks Feature Settings, Part List is set and Migration Settings are set. No messages in Event Viewer. Open STM in Hydraflow or SSA, all pipes and structures visible.
Solved by cyndycyndycyndy. Go to Solution.
Solved by Matt.Anderson. Go to Solution.
Watch your Part matching Settings (looks at Part Catalog) and be sure your part list contains parts from that family.
Thank you, Matt "Stormy" Anderson. My one issue you helped me fix turned into two issues. Since I couldn't find any documented help, I blogged about it: http://c3dcougar.typepad.com/fierce/2011/07/ssa-important-import-eccentricities.html
