AutoCAD Civil 3D - Stormwater
Active Member
carlirwin3430
Message 1 of 5 (498 Views)
C3D to SSA - Catchment to Basin
498 Views, 4 Replies
04-12-2012 07:47 AM
In the migration from C3D to SSA the Basin Icon seems to be located outside of the catchment area of a current design we are looking at.    Is there a way to automate the location of the Basin Icon so that is properly represented in the Catchment area delineated in C#D.
I guess, I misinterprated your question. What I meant to say was, when a subbasin/catchment area is delineated in SSA, the subbasin icon is by default located at the centroid of that polygon representing the catchment area.
The isue you are seeing is because the STM file doesn’t store catchment boundary information – and doesn’t know it’s location.  It’s only schematically relative to the structure – so it comes in at 2:00 o’clock from the structure.  So SSA doesn’t know about the boundary – it only shows it graphically by importing the C3D file.
You may want to drag the Subbasin icons toward the center of each catchment that comes into SSA as a background drawing from Civil 3D. Once you are all set, you can lock the coordinates of the elements within SSA using the Lock icon in the Tool bar.
Product Support
Matt_Haokip
Message 2 of 5 (478 Views)
Re: C3D to SSA - Catchment to Basin
04-16-2012 02:52 PM in reply to: carlirwin3430
SSA by default places the subbasin icon at the centroid of the polygon, so unfortunately there is no option to change the location of the icon.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
Active Member
carlirwin3430
Message 3 of 5 (476 Views)
04-16-2012 06:15 PM in reply to: carlirwin3430
Thanks for the response.   However, the ICONs are not being located within the centroid of the catchment, but are outside of it.  Most cases they are located about 2:00 O'clock.  The catchments we are creating are based on objects / drawn polylines which discharge to an inlet.
Product Support
Matt_Haokip
Message 4 of 5 (447 Views)
04-17-2012 03:17 PM in reply to: carlirwin3430
Matt Haokip
Active Member
carlirwin3430
Message 5 of 5 (439 Views)
04-17-2012 05:25 PM in reply to: Matt_Haokip
Thanks Matt!
