Haven't had a chance to test it yet in 2015, I know in previous versions that if you tried to import a curved pipe into SSA it would straigthen it and when you transfered it back to autocad it wouldn't line up right. is this still the case? or has this been fixed? If not what is your solution to get around this problem?
Mark
As far as I can tell there have been no changes in SSA since Chris Maeder left Autodesk. So what it was or was not doing, consider it still the same.
Bill
